Installation and Usage
xLLiM is distributed as a compiled shared library in a Docker container thus Docker is required. For this example we suggest you build the Jupyter notebook image. The image is built from the offical jupyter/scipy-notebook image adapted to xLLiM dependencies. This image offers the familiar JupyterLab user interface within a Python-based datascience environment.
First steps
  1. Connect to Inria’s GitLab:
docker login registry.gitlab.inria.fr
  1. Get the Dockerfile. You achieve this by using curl or wget:
curl --location -o jupyter.Dockerfile "https://gitlab.inria.fr/xllim/xllim/-/raw/v2/jupyter.Dockerfile?ref_type=heads&inline=false"
  1. Build the docker image named xllim_jupyter_notebook:
docker build -f jupyter.Dockerfile -t "xllim_jupyter_notebook" --no-cache-filter install .
  1. Create and run the container xllim_notebook and bind the volume to your current working directory:
docker run -it --name xllim_notebook -p 8888:8888 -v "${PWD}":/home/jovyan/work xllim_jupyter_notebook
5. You can find the JupyterLab server adress (http://127.0.0.1:8888/lab?token=[some-token]) in the logs. Make sure there is not another Jupyter server running. Use Control-C to stop this server and shut down all kernels (twice to skip confirmation). Here is your personal workspace tree structure:
/home/jovyan/
+-- examples/
|   +-- example_hapke.ipynb
|   +-- example.ipynb
|   +-- JSC1_BRDF.json
+-- work/
    // your local directory bounded to this docker container
You can now open the example.ipynb notebook and try it !
Use your container
Once your container is set up it is very easy to use your xLLiM environment. All changes made to the docker container (installing packages, etc.) are persistent. Be careful not to delete your container, otherwise all modifications made within it would be lost. You can start and stop the container with the two simple commands below:
docker stop xllim_notebook
docker start xllim_notebook
Warning
File permission issues
Depending on your OS and Docker version you may face permission issues on the mounted volume (/home/jovyan/work/ directory). You can overcome this issue by granting file access to the virtual user (jovyan) when creating the container.
docker run -it --name xllim_notebook -p 8888:8888 -v "${PWD}":/home/jovyan/work bash -c "chown -R jovyan:users /home/jovyan/work && start-notebook.py"
After stopping the Docker container you should need to grant back file access to your host machine’s user.
sudo chown -R $(id -u):$(id -g) "${PWD}"
